TwinTurbo.NET: Nissan 300ZX forum - Miles on them is not as important as what they look like.
Subject Miles on them is not as important as what they look like.
Posted by zellamay on September 18, 2013 at 2:21 PM
  This message has been viewed 292 times.
In Reply To Re: First thing I'd do is wrap a piece of string around the four posted by elcid on September 18, 2013 at 12:52 PM
Message If the abnormal wear is visible, it could be the problem. Got a buddy with a Z with good front tires. Borrow them for about 1/2 hour. One thing you can do is switch front to rear (if they will fit) I did this once, even though they rubbed on bumps, just to drive it once to 60 mph. It confirmed that it was not the tires. ....Another thought: if the inside of the tires is abnormally worn, and it's due to sagging or lowering springs (not bad toe-in), there is no adjustment for that. (you have to use the 300 deg kit or adjustable arms). So, I wonder how they could align it.
